erikgreen
- Jan 8, 2007
- 3,105
Just for the record, the Y pipe on an 888 stern drive has 5 bolts, including two way down on the bottom that you can't see when they're buried in 30 years of grease and dirt. If you undo the top three bolts, however, the Y pipe will come off when tugged with a small snapping sound when the metal attached to the lower bolts breaks off.
Argh. Anyone know if there's a way to repair those "ears" or do I need a new Y pipe center? Can I even get one for a drive this old? It looks like the "ears" are meant to seal the lower part of the joint, below two small holes for something, water maybe?
I also sheared the lowest starboard bolt on the transom itself getting the assembly off... it's one of the ones with the hemisphere shaped cap on top. Can I replace these with standard grade 8 bolts? The other side is corroded to half its normal diameter too.
On the bright side, I got everything off the transom, so now I can move on to screwing up the transom itself...
Erik
Erik
