Snapped off bolt in aluminum casing
Elvis156
I am sure I already know the CORRECT answer to this but here goes:<br /><br />Apparently the previous owner of my 1985 Johnson 6hp Sail Master snapped off a bolt in the lower unit holding the middle of the 3 lower unit sections together.<br />This bolt is one that holds the aluminum lower two units to the top unit- lower long shaft is 3 unit sectional.<br />My question- anyone ever drill out, re-fill and re-drill an aluminum casing before?<br />Option 2 is to re-assemble with JB Weld in hopes I never need to disassemble the midl section again- can drop the lower unit to change impellers without affecting this.<br /><br />HELP! Anyone...Anything......any assistance is greatly appreciated.<br /><br />Jason
seahorse5
Re: Snapped off bolt in aluminum casing
Most competent dealers or a machine shop can drill out the broken bolt and thread the hole for a stainless steel Heli-coil repair. It is very common in salt water areas. The new thread will be a lot stronger than the original one.
