snaps
jmccall001
Taking a really close look at sewing a new cover for my 82 sea ray. Notice that I am missing some snaps, look as though they have been pulled out or broken off. How do I replace them? It would sure improve the looks and make the next project easier.<br />thanks<br />john<br />PS Solomons is better boating than the location of the canoe club on the Severn
Mark42
Re: snaps
I ordered this kit from Rochford supply. Snap set includes: 10 buttons, 10 sockets, 10 eyelets, 10 studs and one 2-piece setting die for $4.48.<br /> <br />I should have it in a few days. Will let you know how it works. Best thing is to use a real snap tool, but it runs around $125. Maybe your local rental store has one?<br />
productthumb.asp
18rabbit
Re: snaps
Mark and John – don’t underestimate the quality of the snaps you can put in with that tool. I have one, used it to do between 40 and 50 snaps on a cover. My only suggestion is to practice with one snap/cap and get a feel for it. Also, be sure you are working/banging on a solid surface when you set the snaps. Overall, it’s easier to do than you probably think.<br /><br />Also, check with any local marine canvas shops for stainless steel snaps and caps. They buy them in boxes by the billions and will often sell then very inexpensively. The snaps come in a few different sizes so be sure you get the ones that fit any existing hardware.
jmccall001
Re: snaps
How about the snap portion that is atytached to the boat, not the canvas.
jarway
Re: snaps
John,<br />I bought a snap tool (looks like a pop rivet gun) to replace snaps on my cover and it is really simple to do and use. Found it at a fabric shop called Joann Fabrics but I am sure you can find one at your local store. It is much easier than driving the one you bought with a hammer.
BillP
Re: snaps
You don't need the industrial grade tools to do home projects. The cheap snap kit tools do the same quality work and the only practical difference between them is life span. Both types need the same care in making sure the snaps aren't hammered too hard or not hard enough. Snap construction plays a big part in this too. Cheap snaps are thin and distort easily...expensive ones don't. I own industrial grade now but used the cheap ones when I first started doing canvas. The tool from JoAnn's Fabrics is a deal too. It's a press type so you can do the snaps with the canvas in place...no hammering and saves time. I use a revolving head leather punch for making holes. Cheap punchs like this can be found at HarborFrieght for $5.<br /><br />Snap material is a personal choice but I don't use stainless because it can spec little rust dots on the button and stain the material when folded. Nickel plated brass doesn't do this and will still look new in 5 yrs without a problem. These have ss springs though. In Florida, most marine canvas shops are using DOT ("Durable" model)brand NPB...that's what I use. One last thing on buying snaps. Make sure the stud is long enough to go though all layers of material and still have enough length to curl over when set with the hammer. Corner overlaps are the place for sizing snaps.
