I just installed a new trailer jack and decided to raise the bow of my new to me '75 Jupiter. Then, as I raised it up higher and higher I heard... glurppp..... water starts pouring out of the drain plug.
Dreading the sound, I now knew the boat had been kept outside and probably uncovered. Great. The floors had felt solid, and I had felt dry foam under the deck boards. I crawled under the boat and looked carefully. It looked like there was some odd green substance brushed onto seams where they had tried to seal leaks, and a small 1/4 inch hole on the keel, likely where the boat had hit a rock of some sort.
I will now pull and replace the floors over the winter. The boards are easily solid enough to make a template. How hard of a job is this?
How hard is it to seal a leaky starcraft? Is it as simple as gluviting every seam?
How might I seal the hole? I could drill it out and insert a big closed rivet in there and seal with gluvit?
I hope it's really that simple!
