does anyone know what else i can try? not sure what do next, all fuel lines have been changed including tank, i have been using sea foam in the gas since i got this motor, carb kit installed, new fuel pump, geting spark in all the plugs, used a tester on all the plugs and wires, compression tested they are all within 10% of each other, new plugs, i do have a exhaust gasket leaking under the power head, but i tried running it on the lake without the engine cover and still the same, new water pump. please anyone with anymore help would be greatly appreciated
