Been having a leak near the prop on my lower unit (28HP SPL Johnson). I finally tracked down the year of the motor, which should be: J28ESLED 1996
The lower unit is a split case... and thinking it was only my seal, I just removed the bottom section to "see" what's involved. Looks straight forward, but I have afew questions.
Based on the pictures, does the SEAL separate from the from the bushing easily? Should I be replacing any other parts, while I'm at it?
Do I need to drop the whole lower unit for this job? The shaft seems to be held in place just fine when I removed the bottom section. But I dont know if I can get access to the seal like this halfway?
Let me know if I am going about this all wrong. I know I'm taking a slow approach, its the first lower unit I have dropped... Seems straight forward and within my skillset, but I just want to be sure I am looking at the right stuff.
Also: Some other stuff I noticed. The bolts all had this "crusty" "gluish" stuff on them. I know there should be sealer used, but this stuff doesnt look right. Is it just old? AND... What is this black spongie part in the skeg? Is it just build up or some kind of part? I noticed its movable when I touched it.
NOTE: The gears looked amazing, with no wear. No shards in the oil either. I have more pictures, if this might help anyone else down the road.
