So much help needed
dafson2
I have been working on a 1984 50 hp force for quite some time. When I first purchased the motor it would start fine other than needing a carb job. One weekend I went out to start it and when I turned the key nothing happend and such has been the story for many months. I have replaced the startor motor, starter selonoide, rectifier, neutral safety switch, and finally the ignition switch with the same result each time. I have tried a few different batteries changed connections on all wires. I cannot think of anything else to change if anyone has any ideas they would be very much appreciated. other than basic mechanical skills I have no idea what im doing with this motor, this is my first one, thankyou.
maxum247
Re: So much help needed
Are you putting the lanyard clip on the kill switch when trying to start engine?
Recheck all ground wires and wire connections and any butt connectors. I know you said you've done this already but there might be one you've over looked or didn't get connected right.
JB
I was gonna say, "PLEASE stop throwing parts at it!" but I don't think there are any more parts to throw at it.
Now, do what you should have done in the first place. . .troubleshoot.
First, get a manual and use it.
Then go to the Engine FAQs and do "Outboard won't start".
Let us know what you find.
