Socket Size for EZ Lube Hubs
ralphy670
What is the socket size for the bearing retaining nut on a Dexter EZ Lube hub/ I have a 3500lbs axle trailer for my Tahoe Q4.
Thanks for any help.
Prophammer
Re: Socket Size for EZ Lube Hubs
If you don't have a set of sockets to keep trying 1 after another, you may be able to tap the nut loose with a blunt punch, being careful not to damage any locking device or chipping off any metal. With nut removed measure it for wrench size, or maybe you can do that without removing it, or... if the nut is not in-set too far, you may be able to get adjustable wrench or channel locks on it!
