Solar panel for charging battery?
Anybody using a solar panel for charging their battery? If so, how many watts are you using and how good does it work?
petryshyn
Re: Solar panel for charging battery?
I'm using a 12 watt, and it works fine. Apparently WalMart is clearing them at around $80.00 Can.<br />I've tried a 2 watt, but found it too small to recover any appreciable discharge. It may be good enough to ward off "shelf life discharge"<br /><br /> :)
ob
No retail outlets in south texas carries them .Had to order one for attic fan from catalog.Probably political issue.
Steve135
Trannywrecker- I have also used one . I found it didn't hold up to the harshnish of the sea! It was hard wired to the batteries, tended to get in the way at times. I don't know the watts.I found using the boat at least once a week was all that was needed.<br />steve
72 mako 19
A 5 watt battery saver by icp has done me wonders. Go to Northerntool.com for lowest price. Dual battery set up on 88 johnson with 3 year old marine batteries. Solar panel is only hooked up when I am in dockage, recharges the batteries and maintains charge when i am not using the boat. And when I use it, starts right up on first or second crank. Before I had it, it would be a miracle if it starts on sixth try. Also, fluid level in battery doesn't fluctuate as much as it used to. Been checking battery every week and fluid is still full and charge is more than 75% all the time. I am a firm believer in SOLAR PANELS. My slip neighbors are all getting one since they have seen how it works.
DIRTPOORE96
Hi Trannywrecker, I have a 5 Watt on each of my batteries & they seem to work great. I also only use them at the dock when I'm off the boat for the week. When I go out I take them off & put them away. You can get them on e-bay for under $50.00 U.S.
Thanks for the info guys...I'll definitely look into buying one now.
