biglurr54
- Feb 14, 2011
- 234
Im building a list for my party boat rebuild and have an idea on the battery/ stereo area. I am going to use a 300/4 channel amp for the power which will run off my cell phone. This will drive 4 6.5's in home made PVC tubes up on the bimini. I have a very similar set up in my bow rider and it pulls about 5 amps max. I dont blast the speakers. Just enough that you can enjoy music on the boat or in the water. I have been left with a dead battery while on the lake. Lucky my motor is tuned well and I have always been able to pull start it with a rope. Not an easy task as its a 120 hp looper. I have it setup for 2 batteries with an isolater but the cost of buying two new batteries ever two years was adding up. I went with one battery this year and had some issues with it. I began to buy starting batteries from walmart for $100 with three year warrenty. The party boat will have a higher electrical demand than the bow rider because it wont turn high rpms while running and it will do alot more drifting while the musics on.
My thought was to buy one walmart starting battery for $100. Then buy a 100 watt solar panel and 10 amp solar charger for the panel.
The panels can be had for $120 and the charger is $25. If that saves me from having to only buy one battery every three years instead of two batteries it pays for it self pretty quickly. If the stereo is pulling 5 amps while in use the solar panel will put about that much out. This should mean the battery will always be at 100% unless its cloudy which we wouldnt be out or if were out at night. If either of those situations were the case i would have a battery at 100% to start with which should suffice those two circumstances.
Anyone see a problem with this?
