Solas prop is factory?
Wee Hooker
Just picked up the new 30 HP Nissan. Was suprised to see that they (Nissan) shipped it with a Solas vs OEM stamped brand for a prop. Not gripeing, just shareing.
pvanv
Re: Solas prop is factory?
The High Thrust props for 4/5/6 and 8/9.8 are made by Solas.
TOHATSU GURU
It varies depending on the prop. The 20 and below come with a Tohatsu produced prop from Japan...But, about 50 % of the replacement props that we buy from Tohatsu are SOLAS. On the 25 and larger about 80% are now SOLAS. Tohatsu's explanation was that SOLAS could produce a prop to Tohatsu specifications for less than what Tohatsu could build one for. I personally don't like it, but at least SOLAS is made in Taiwan and not mainland China.
kjellejon
I have a tohatsu 25 hp efi with std 11 pitch solas propeller. My top speed varies from 28-30 mph. I gain top speed when i trim out and the prop ventilates slightly.
I am wondering about the solas saturn. Is there any conversion table for a std alu and a solas steel propeller with similar performance, same wot?
Do i gain anything in converting to a solas steel prop, more bow lift and or less ventilation, or is the only way to lower the engine on the transom?
pvanv
This could go in the prop forum...
