Re: solenoid bad? starter...
Be sure your battery is fully charged. All wires connections clean and tight. Clean and lube the shaft on the starter that the bendix slides up and down on. If all that is good, try running 12V straight to the starter using heavy wire (like jumper cables). If the starter acts normally then, replace the solenoid. Let us know the results.
