smokeybandit
- Aug 1, 2003
- 5
Hello, I have a 1969 SeaRay w/Mercruiser inline 6 and it has 160HP. I have had a problem with the battery discharging over night ever since I bought it. I am on my third battery now due to it going bad. I have traced wiring and found a solenoid that was located under the exhaust manifold directly behind the alternator. The part number for the solenoid is 25661 and can be found on the following web site: http://www.mercurypartsexpress.com/PartsExpress/ProductSelection/Accessories/getProduct.asp?sku=25661&SPHomeqty=&store=ServiceParts&statusMsg=The+part%3A++25661+has+been+substitute d+with%3A++25661T+1&CID=170162190069225061272<br /><br />There are four terminals on this solenoid and the front two are labeled - S & I but the outer two are not labeled. Does anyone know what the outer two are supposed to hook up to? I want to double check this because I found a ground wire connected to the terminal - I. Just to make sure the S=Starter and the I=Ignition?<br /><br />Thanks for your help,<br />Bruce
