Solve this Alpha 1 problem
Ryan00TJ
Bought a Alpha 1 over the winter to build up for a spare drive in case I grenade my primary. I bought a GLM lower gear kit with all new gears and bearings and 1.50 Heavy Duty upper gears with all new bearings. New Merc prop and vert shafts. I set it up by the Merc service manual.
Installed on the boat and fired up on the trailer to check shift operation. Everything fine.
Took it down to the lake to break everything in and it was fine, until it would not shift into reverse. Forward was fine. Came home pulled the lower half and disassembled. Nothing torn up, gear pattern looked great, nothing major on magnet. I then noticed the F gear needle bearing had backed out and was hitting the spool keeping the clutch from engaging the R gear.
I figured it might not have been pressed in all the way so I pressed it in and retested today. Same thing happened, shifts fine for 5-6 shifts and then won't engage R. Pulled apart and it's the same thing.
I've been around Alpha 1's since the early 90's but this has me stumped. Nothing contacts the needle bearing to push it out. If you replace the bearing per the service manual you have to cut it out. I can only guess that either the needle bearing is undersized or the gear is oversize and the bearing works it's way out?
What are my options? What could cause this?
Reel Poor
Re: Solve this Alpha 1 problem
Did you install the bearing with the lettered side out, away from the gear?
Ryan00TJ
Thanks guys.
Seaman, That's pretty strange.
Rear Admiral, Yes bearing is pressed in the right way. "Torrington" lettering facing out.
Don S
I've never run into that problem myself but did find Merc lists 2 bearings for that application.
One a 31-42679 with a Torrington #GB-1616.
The other is Merc 31-30895T with a Torrington #B-1616
Perhaps there is just a slight difference in size? ? ?
Ryan00TJ
Thanks guys! It's loose enough that I could push it out with little pressure so it must be a oversize gear. I talked to a former Merc tech that's friends with my Father and he said to try Permatex Bearing Mount and reseat. He said he has used it in the past and it's never failed on him. I'm going to get some and reseat the bearing and go from there.
Reel Poor
Ryan00TJ said:
he said to try Permatex Bearing Mount and reseat. I'm going to get some and reseat the bearing and go from there.
Before I did that I would check the specs on the other bearing Don listed. You may have the wrong bearing.
Ryan00TJ
Yes I am going to my local bearing supplier and going to check out both Torrington bearings. Going with the one closest to the ID of the F gear.
Thanks again for the help.
