nerys
- Jul 23, 2009
- 41
I am about as broke as I have ever been in this economy yet I have more toys than I have ever had before! While I have zilch for cash Bartering has proven very successful
I now have 2 boats. a 27ft sailboat with trailer and a 19ft power boat with trailer.
Got the sailboat for $150 and the larson in trade for a rusty only 75 300D I had.
On the larson I am seeking some pointers etc..
its a 1974 All American 186 with a 1978 140hp Evinrude.
The floor seems ok but the deck is shot. I have already ripped it out tossed in a sheet of 3/4 ply so I could enjoy it right away
I am hoping if I just list everything I found wrong with it that maybe those more knowledgeable than me can point me to a good thread url or book so I can start the restoration/update.
It runs and functions. Had it out 3 times already (just spun the hub in the screw so I have to replace that before I can take it out again)
I am specifically looking for construction details for this boat. I need to know what I am looking at so I know how to proceed. I plan to do 99% of the work myself (can't afford to pay anyone anyway)
When I remove the "deck" I don't really want to call what was there a deck
hehe
the plywood was so rotten it came away as PASTE under my fingers! I knew would could get bad but never knew it had a liquid or gel state
hehe
well thats all gone now. I put it nose down power washed the living crap out of it and then put it nose up and let all the sludge go away. Did this a few times.
I did some research on boat construction and this one seems odd. From what I read stringers on on the inside of the hull but ATTACHED to the hull right?
once I got rid of the ply floor/deck I discovered mostly FOAM except in the bilge which is void of material to the glass inner hull surface. (I have not gotten to the bow yet it seems solid and I am too big to get in there for a close inspection will have to attack that if I manage to pop the cap off this winter)
How do I determine if the foam is compromised?
There is "wood" embedded in the foam but its clearly NOT attached to the bottom of the hull.
is this simply support points for the deck? ie can I simply shovel dig this goop (thats what it is now) out and replace it? is there something NON wood I can replace it with? I am hoping maybe I can find some scrap aluminum or something. is there a reason it was wood. should I use wood or is it ok to replace it with something else? since there is not MUCH there I was thinking of making some FOAM 2/4's and laying up some kevlar carbon weave on the foam 2/4's as a "form" and using that. is that ok? how does layed up carbon and kevlar handle a moist environment? I use it in rockets all the time but rockets do not have to deal with water
Is the foam GLUED to the hull? ie can I remove the foam in blocks so I can reuse it later or does removing it destroy it? (so I can access the stringers?)
the Transom seems ok I grabbed the motor and shook it hard enough to rock the boat in the trailer no give no undue flexing feels rock solid.
Found a guy who will bottom pain for $360. is that a good price? (the bottom is in rough shape. the glass is ok but the pain is pretty much gone chipping peeling etc.. many layers it seems. I ripped a piece of amateurishly applied glass to what seems a patch job (have not looked at it closely yet) plan to redo that.
Ok the hull appears to be 2 pieces. top half and bottom half.
they do not appear to be JOINED in anyway I can see except by this aluminum "stuff" that is aluminum rubber aluminum bumper around the entire perimiter of the boats edge where the top and bottom half joins.
Its missing a section. HOW is this secured to the boat? (they shove some SCREWS into it in a few places and into the hull obviously this is not working so well its just tearing holes in the fiber glass.
How do I maintain repair replace this stuff? where do I get it?
the part where its missing (starboard amidships to aft around the corner to to its termination point.)
the two halves of the hull are not quite aligned right anymore and the "lips" are chewed up a bit.
suggestions?
Gel Coat. its got tons of tiny little stress cracks especially anywhere there was a penetration (such as the "snaps" for whatever cover it used to have)
I found some videos on gel coat repair it does not seem hard to actually DO but color matching might be a problem.
I was thinking of removing the top plate upper half of the hull doing all the little dozens and dozens of gel coat repair in simple white and then taking it to someone to shoot a color on it.
will that work? will regular automotive paint and clear coat WORK on this? ie last and be durable? I would love to re gel coat the whole top but I have a feeling that such a task would cost more than the entire rig is worth.
The window is in sorry shape. they appear to have tried to use some goop to attach it. I am not even sure IT IS attached by anything more than this goop crap they have on it. How are they supposed to be attached?
part of the problem seems to be the bow is "sagging" and forming a bow shape. I think I can fix this. there is a wooden structure in the middle that would seem to structurally SUPPORT the center of the boat top half right there. its shot to hell. I am thinking if I replace that it will restore support to the bow top section and reflatten that surface for the wind screen.
suggestions?
also can I alter the windscreen? its too low. even with the back to back seats on the boat (way way too low painful for me to sit in at 6'3") I already got some 13" tube seat pedastals will get swivels and bucket plastic seats next week.
this is going to put my head quite a bit above the window. I am thinking I could stand the window straight up and just change the "side" pieces on the wind screen to support this new angle. Is this feasible? suggestions? Can I get a taller wind screen that will fit this boat?
how is it even supposed to be attached to the boat. I really think if I yanked it that it would come right off though it has not move yet (it moves like a hinge fore and aft though but has not "lifted up" yet so I figure SOMETHING must be holding it in place than just the crap they used to try and seal it?
It has a few wiring issues but the wiring is very minimal and simple won't be hard for me to just run new wire to the problem items (right now I just hook the stern light directly to the battery when night comes
bow light still works but its only $13 at wally world so I will replace it so its new and shiny (the one on there is faded and pitted)
the outboard lower drive unit ?? is pitted REALLY badly How do I repair this? ie how do I "refinish" the surface? is there a marine epoxy that will adhere to this so I can "fill in" the pits and refinish paint it? ie what is the right way to deal with that? Can I grind down the metal (I fear that might make it too thin!) ie whats the procedure for repairing this? what causes it?
anything else I should look at deal with take care of?
the boat is a bit too small for my tastes. I want to TRAVEL places in the boat so I need faster (It maxes at 24mph right now though the hub may explain part of that) and a place to sleep for overnight weekend trips. but for something to place with restore and have fun with till I can afford bigger its a blast so far. Very happy
any help suggestions reading sources information etc.. would be greatly appreciated!
I am going through that massive thread now where someone extended there boat. its good reading so far
Thanks!
suggestions?
suggestions?
Thanks!
