the last few days my boat has been acting up a bit with regard going into gear. will try an explain as best I can.
When Put down the throttle stick on my boat goes into forward gear OK i think as the prop starts to turn very slowly boat hardly moves but wit no kick, But then when it reaches 1300 revs it kicks in like it normally would. and of it.
I disconnected the throttle cable from the handle and put the handle in the full down position and nothing. but then when I go the the carb and manually bring the revs it to in around 1300 or more it kicks into gear.
Thanks for reading your help would be appreciated
Colm
Colm
