Gas Giant
- Aug 8, 2010
- 239
'61 Evinrude Big Twin 40hp model no. 40353
Got the engine running, and it idles halfway decent, but I never did adjust the low speed needle properly, and I wanted to see if I could tune out a shake the engine had at idle.
So, I tried the Joe Reeves method today, which states as follows:
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
But, I ran into some problems and am looking for some advice.
1) The very first sentence says to "Start engine and set the rpms to where it just stays running." I'm not entirely sure how to get my engine to idle any lower than it naturally wants to. The Idle Stop setting on the control box and the Idle Adjust knob on the engine itself only seem to be able to speed it up, not slow it down - it never hits a point where it just stays running, it always idles at a speed which seems fairly strong....so CAN it be adjusted another way?
2) I decided to proceed anyway....well, that stupid low speed needle valve wouldn't seat! I tried adjusting the packing nut tightness, but no matter what the needle just wouldn't seat - it would just spin and spin. In fact, it turned those packing washers into shredded wheat. So what happened? What do I do to prevent this from happening?
Obviously, I have to get more packing washers, but hopefully I'll be attempting this again tomorrow, so any pointers are appreciated.
Just in case anyone asks, the ignition is new, the engine has an even 100psi on each cylinder, and the carb has a fresh rebuild on it.
(J. Reeves)
