jason32038
- May 25, 2009
- 555
Here's my story...'86 85 hp force. Tried pulling flywheel with 1/4-20 grade 8 bolts and the bolts ripped right out of the flywheel. Tapped to 5/16 and used grade 8 and one bolt ripped out. Took it to marina and the guy couldnt get it off either. Here's how I got it off...I had the powerhead on the ground pistons facing up...I used a small cro-bar between the top of the water jacket and the flywheel. Pryed a few times and held it...hit it hard 3-5 times with my klein 16oz hammer...rotated 1/4 turn and repeated the process until the flywheel popped off. The nut was a pain in the *** to get back off because I smacked it wrong a few times. It didn't come off with much force it must not have ever been removed. This was a last resort I wouldnt reccomend you try to remove the flywheel like this unless you cant get it off any other way. Also don't pry too hard just hard enough until you see the flywheel move.
