Sometimes turn key & nothing; sometimes starts
stevejeri
I have a '73 115hp inline 6 Merc. Sometimes I turn the key it turns over fine. Sometimes I turn the key and nothing, but if I tilt the motor all the way up and back down, it turns over. Would it be a wire grounding out sometimes or something more serious?
Thanks
Barnacle_Bill
Re: Sometimes turn key & nothing sometims starts
Either a bad or loose connection, ignition switch, starter solenoid or even possibly the starter. But from your description I would look for a loose or dirty connection.
Chris1956
Re: Sometimes turn key & nothing; sometimes starts
Start with checking the quick disconnect plug. That is where the most flexing occurs
1730V
Quick disconnect plug is a great place to start. Do a wiggle test. Have someone turn the key while you shake the plug.
Also remove and clean the negative battery connection on the engine block.
