Sonair 6.4 - Looking For 4.3 To Rebuild.
Sonair 6.4
Am looking to buy a 4.3L 4V to rebuild found one for 1500AUD with approx 2300hrs seems dear to me any help would be appreciated
Hence the shout out to our up-side-down-under mod....
GA_Boater
When I saw 1500 AUD right after the thread was opened, I knew I couldn't help from GA, so I didn't reply. Guess maybe I should have.
achris
More fish than mountain goat
Hey achris .... Any pointers for sources of 4.3s down under?
Not an engine used in any vehicle in this country... I wish there was... Importing from the U.S. is our only option, and the government slap their slice on too...
Chris....
Sonair 6.4
Would I be better putting a 5L instead of the 4.3, not sure if the weight would be a issue
achris
If you're referring to the Australian 308, forget it, different engine to the yank 305...
Chris....
achris
No just the mercruiser 5L
Yeah, that'll bolt straight up, most of the accessories will also bolt on. You'll need new exhaust manifolds and the the aluminium tubes below the exhaust elbows...
Chris....
Scott06
You need four inches in front of the existing 4.3 to slide in a 5.0 or 5,7, also side mounts on engine block will be 4” farther forward as well. I did the same swap 4.3-5.0 on my boat but the boat was offered with a 5.0 from the factory so the engine compartment was big enough and the stringer mounts were 12” long To accommodate either engine configuration
would definitely measure before picking up an engine as it would be a lot of work to stretch the engine house in some applications like mine where the bench seat is in front of the engine, stringer mounts can be glasses in fairly easy though
