source for affordable points?
RL
Does anybody know of an affordable source for new ignition points for a '71 evinrude 60hp 3 cyl?<br />The jokers around here want $27-$37 for each point set ( i.e. $54-$74 for both). That's highway robbery for something as primitive as a point set.<br />I checked at NAPA but their catalog doesn't appear to list the points for this engine.none of the online places that I have looked at so far list them either.<br /><br />Any help would be greatly appreciated.<br />Thanks----Robert
JB
Re: source for affordable points?
That's the price of running a 33 year old engine that is getting pretty rare, RL.<br /><br />You might consider converting to the later style ignition system.<br /><br />You might find a set of good used points at one of the salvage houses. www.twincityoutboards.com is a good one.
Chris1956
RL If that motor is a magneto, you may be able to replace the points with one of those "Magnatune" point/condenser replacement units. I think it needs to be one set of points and condenser for each cylinder however. It sounds like your two sets of points "cooperate" to fire all three cylinders.
RL
I did a search on magnatune and so far, all of the results that I found were for engines that do not have a charging system.
