Re: source of outboard problems?
Well both I would assume both, as the electrical system needs attetion as in tightening connections and cleaning corrosion. The fuel system needs attention to fuel age and quality, water in fuel and oil tank is a sure way to disaster.<br /><br />Engineering problems can be both as in the wiring harnesses in older mercs and in fuel injectors in the johnson fitch motors of the late 90's which could be both electrical or fuel depending how you look at it. <br /><br />Most newer outboards are well thought out fine pieces of machinery and to endure a life of not being run for weeks and sitting in water, to hours of near wide open throttle to hours of idle time it is amazing that any of them last more than a few weeks!!!
