TheRealTeeHill
- May 5, 2013
- 13
Is there a reliable and fairly priced source in the UK? Or will I be putting in an order with America?
I'm in need of a new prop, prop clutch, some lower unit oil (probably get this at the local chandlers), points, coils, lube wick, spark plugs, float and float pin for carb (I have a cork float and although it is still shiny I'd prefer a plastic one) and impeller for water pump. If I can afford it I'll go the whole hog and grab service kits for the water pump and carb.
Cheers, Tee.
Cheers, Tee.
