Southwind Boat Parts Florida
robmcconnell
Hi
Looking at buying a Southwind 2400 and it needs a few things. Portside rear cushion is missing and I wanted to see if they had a factory fitted extended bimini or if it was an aftermarket option.
Maybe someone might be able to shed some light on the bimini if you have a southwind.
Cheers
Rob
southkogs
Quick look on the internet says that Southwind was owned by the same company that is now Sailfish boats. You might be able to contact them for some details.
My guess on the bimini is they probably had someone make them for the boats and then rig them (if it wasn't done by the dealer). Rear cusion could be made by a local upholstery shop if need be. Or if you have the same cusion on the opposite side, you might be able to use that and make a pattern to make your own.
if your boat is over 5 years old, the manufacturers would not have access to soft parts like cushions and bimini fabric. Most of that stuff is only around for a few years and then it changes. Boat companies do not keep inventory beyond the warranty period.
your best bet is a local upholstery shop
