spacer location
Bt Doctur
Really have to give us more info ,Didi you replace the rear motor mounts?
Did you loosen and free up the front adjusters?
Bondo, wasnt there a post by the late Don S about first timers posting something
Ayuh,....... Lotsa great info was lost when Don passed,.....
Everything in his Adults Only section was lost,.....
barnyard
there is a spacer (coller ) about 3/4 thick that goes thru rear engine bell housing to transom mount , one on each side Rear motor mounts
Scott06
I assume you are talking about C in the pic in this thread ?
if you have the older style with the springs that is a different animal but as mentioned above helps folks to know what you are working on
Also as BT suggested loosen the front mount - easier if you have crows foot socket to adjust (depending on engine compartment)
barnyard
thanks Scott.exatally what I was looking for. also thanks to other replies
