Hey guys,
I just purchased a 14.5 x 19 Merc aluminum prop off of Craigslist. My stock prop is a 23 pitch, but for $70 I figure this will work great as a spare.
I'm planning on purchasing a spare prop nut and washer just in case I drop one in the lake, as well as a floating prop wrench. I'm pretty sure that the stock prop hub will work on the new prop, but is it worth buying a new one as a spare? Am I likely to damage the hub if I hit something with the prop?
Is there anything else I should buy to keep on the boat as a spare? Also, I noticed that the prop nut has a rubber part that prevents the nut from turning on its own. Do these wear out over time, or are they good forever?
Thanks everyone!
Thanks everyone!
