haulyard
- Dec 29, 2007
- 71
my johnson 40 hp model 4cesl69r has spark on bottom wire but no spark on top ,i checked the points and they are correct,does this motor only spark on both when a certain rpm is reached or do i have one spent coil???
And is there any way to check the electric shift by applying voltage to the wires that head down int the lower unit? i disconnected the wires under cowling and they have voltage when i use my selector switch(power to green for forward and power to other wire for reverse and no power to either when neutral is pressed)does motor need to be running to check them?
thanks
thanks
