I just put my 1994 5.7 mercruiser back together (http://forums.iboats.com/showthread.php?t=559261) and it is running well except for this MAJOR issue. Once we got the timing adjusted and the distributor aligned correctly, the engine fires right up, better than since i have owned the boat (5 yrs).
However, as soon as it starts there is a loud clicking sound. I finally found it after about 5 minutes of running the engine. I have a spark jumping from the center wire on my coil to one of the side terminals.
I have pulled the boot off the coil center and adjusted it, the spark still is there reaching across to the side terminal.
I know this is a mjaor issue as if I continue to operate it this way there will be an explosion at some point.
What would cause the coil to spark to itself?
Will I have to replace the coil or can i just replace the coil to distributor wire with a new one?
Thanks.
Thanks.
