midsized johnson
- Jul 28, 2005
- 155
90 model 85 Hp Yamaha 3 cylinder. My buddy was running at around 5200 rpm, everything going good until, bam! Sparkplug blows out. He took the cylinder head off, and everything looks clean, but the upper cylinder part of the head has some hairline cracks. It doesn't appear that the piston came loose, more like the head got hot, cracked, and compression shot the plug out. He says the thermostat (new) looked messed up. I'm pretty sure the thermostat wasn't working correctly because on a test run last week he pointed out that no water was coming out of the exhaust ports while running at upper end speeds. I know that on my outboard, water dumps out of the exhaust ports at anything other than idle speed. BTW, he says the cylinders look good, and the motor isn't locked up. Any advice on what to check for, other than replacing the cylinder head and, of course, the thermostat?
