Spark Plug Gap Changing Every Time Motor Starts
cprince
Have a friend who has a 9.9hp Rude. Every time he starts it, the plug gaps change (get smaller).
Sounds like a piston head is slapping the plug to me. If the plug is the correct one, what would cause the pistons to travel too high? Crank shaft bent?
(I know that this is thin on info, but this is how I got this problem sent to me!)
Craig
walleyehed
Re: Spark Plug Gap Changing Every Time Motor Starts
Carbon build-up possibly...What plugs?
cprince
Thanks for the reply walleyehed.
I am still trying to get more info from him!
Post more when I get more!
Craig
walleyehed
The only other thing, if they are the correct plugs, would be potentially bad needle bearings, but you'd have other issues there.
tschamp20
exactly what i was thinking.your friend should really take off the head and look for any pieces of metal.if the bearing goes,so could the connecting rod,piston,cylinder wall and head potentially. trust me i know.
a70eliminator
Craig
Thats a very big "IF"
R.Johnson
If it effecting both plugs' I would check for wrong spark plugs with a longer threaded shank.
noelm
OK, lets assume the motor is OK, it is possible the head has been machined at some time and then done again, and is now too thin, try to fit another washer (or two) on the plug and see how you go, a bent rod is not going to cause your problem (it will actually cause the opposite) and a bearing that bad will certainly be audible when running.
Vic.S
You dont tell us the year but:
1974-76 UL81C
1977-94 QL77JC4 or QL82C
1995 and newer QL82C
They are all the same length reach ... defined by the letter "L"
Not lost the sealing washers ?
wilde1j
Easy to confirm the piston is whacking the plugs ... remove the plugs and shine a light on the piston top. If it's hitting the plugs, you'll see the marks on the piston tops.
cprince
You guys are tops!!
Turns out, much to my horror, he put in any old spark plugs! Too long...
Now to add to the atrocity, someone put washers on them to act as spacers.
I warned him about too hot or too cold causing possible damage to his motor. Hope he takes the warning.
This all leads me to this question, if the piston slaps the plug and the piston is now marked, what kind of affect is there on the engine performance?
Thanks!
Craig
PS
Motor is a 69 'Rude, 9.9hp
Craig
R.Johnson
If the piston hit the plug only enough to bend the ground strap with out completey closing the gap, probably nothing. If the piston smashed the gap shut, the engine would not have started.
