donald maclaren
- Jul 30, 2017
- 2
I was reading the followig in a old post
BTW, should probably check to make sure that NGK BPR6EFS is the proper plug for that engine. 0.45 is the correct plug for that spark plug however.
I do know that Volvo has changed recommendations on plugs on many of these engines to the AC iridium plugs that are pre-gapped at 0.60. I would not be gapping those NGKs to 0.60."
I have a 2007 red volvo 4.3L GXI-g engine. pulled out old 41-993 Ac plugs and gap looked to be around the .05 - .0525. The new 41-101(next model up from 41-993) are gaped out of box .06. So Per my manual they say .06. Engine would not turn over. I pulled and gaped to .045 that I saw on some sites for the 4.3L EFI engine.
it started up just fine in drive, have not lake tested, ran for like 5 minutes and smooth.
I also read where people say you can't gap iridium plugs, is this even true, how can you sell a plug you can't gap?
My ultimate question is, how I can find out exactly what I should be gapping these 41-101 Ac Delco iridium plugs to on this engine? Any infoi or places to search or anything would be helpful.
Should I gap at 5 or 5.25 and split the difference? the iridium, do they inherently need smaller gap?
Thanks,
Don.
Thanks,
Don.
