This maybe okay on a spark plug with a built in metal gasket, but, Not a good idea if you have a spark plug with a beveled base, and no gasket, they're only 1/16th of a turn after hand tight. Plus, never change plugs on a hot, or warm, engine, you can strip out the threads on an aluminum head, I've had that happen on an old outboard I had (even though I was careful taking it out!I have always gone finger tight (snug), plus a quarter turn. That is what my dad always taught me 35 years ago, and it works.
This maybe okay on a spark plug with a built in metal gasket, but, Not a good idea if you have a spark plug with a beveled base, and no gasket, they're only 1/16th of a turn after hand tight. Plus, never change plugs on a hot, or warm, engine, you can strip out the threads on an aluminum head, I've had that happen on an old outboard I had (even though I was careful taking it out!), Yeah, I had to take the head off then, & have a helicoil put in.
Good point, as far as I know, everything I work on has the metal gasket on the plugs. To be honest, I do it more by feel now. You can tell when it is tight enough, it stops turning with the strength of my wrist alone in a twist motion...not very scientific, but so far so good!
