I have a 84 115 Mariner. It just started fouling the second from the top spark plug. It will run great for a little while then start running bad. If you pull the plug out it will have some carbon on it. Clean it off & it will run fine again. The motor had a carb job,power pack, & some other things replaced the first of the summer.<br />Thanks for your help.<br /><br />Mark
