spark plug tester in Canada?
Rick.
In a recent post jbjennings showed a picture of a spark plug tester he bought at Autozone for under 7 bucks. Is anyone aware of a similar tester available in Canada? I've asked at all the local stores and I get a blank look from the sales staff when I described it. Tried Autozone and the first thing they ask for is my zip code. Can't get any further than that. Thanks, Rick.
Rick.
Re: spark plug tester in Canada?
Edit: I meant to say spark tester. Sorry, Rick.
samo_ott
Try Canadian Tire or Princess Auto. I have one and got it at one of those places, I just forget which one, I think it was PA though. And they are VERY handy. I was using mine today.
AEROCOOK
Master Chief Petty Officer
Princess Auto item # 8003334 $4.99
wilde1j
It's also easy to make a needle point adjustable gap spark tester. I made one years ago, and I think Joe Reeves posted directions somewhere to make an even simpler design than I built. See below:
Joe Reeves Joe Reeves is offline
Default Re: Arcing to engine block
No, not really. That tells you that there is a spark of sorts but it's best to have a regular spark tester. You can make one for next to nothing if you wish.
(Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
http://stores.ebay.com/Evinrude-John...tc?refid=store
