spark plug wire popping off
js5278
1984 40HP Evinrude. Strange problem. Twice in the last three times out I've suddenly dropped to one cylinder and when I opened the cover I found that a spark plug wire popped off a spark plug. Top cylinder first time, bottom today. Reconnect and all is well. What could be causing this?
kenmyfam
Re: spark plug wire popping off
Replace it. It's that simple. While you are at it, replace the other one as well before it does the same.
Not bad after 16 years eh ???
R.Johnson
Are you snagging the plug wire with the hood latch?
js5278
No. Each wire has done it once while the motor was running. Actually, the first time it happened both boots on either end of the wire were off. Otherwise the motor has run flawless for me since I bought it about 7 years ago. This happened today and about 10 days ago.
kenmyfam
See post #2
samo_ott
That's very odd. Try squeezing them tighter, or if you have to replace the end of it. They're cheap and easy to do.
And kenmyfan, is that how you Canadians do math? try 26 years old!!!
kenmyfam
I gave it a 10 year discount !!!:eek::D
Tim Frank
You Canadians? :confused:;)
js5278
Thanks guys. I was on the water for about 6 hours today with no problems. I'll replace the wires.
1946Zephyr
Hmmmmm, never had that happen before.:confused: I usually give the boots a slight twist back and forth when I put them on, so they wouldn't just pop off.
