spark plug wiring kit
stormmn
thanks Chris, found a dist. cap to plug wiring kit.
Question, the screw in ends in the kit that go into the dist. cap are not crimped or attached to the wires.
how do you attach the cable wires to the screw in ends????
is their a special tool or can they be soldered...
thanks for any information.....
Chris1956
Re: spark plug wiring kit
You can buy the original yellow "Tiger Tails" for that motor from oldmercs.com or vintagemercs.com. These have the screw in connectors already crimped on. You do need to add the spring and boot ends that fit the spark plugs.
