Spark Plugs 1990 Force 120
redlabel
Does anyone have suggestions on spark plugs for a 1990 Force 120? When I bought the boat, they had L76V Champions in it. The book said I should use UL18Y Champions, Prestolite system... unless it is a Thuderbolt system which uses the L76Y.<br /><br />I have been having some major fouling problems which I think I fixed (idle mixture screw was backed out 3 full turns), but want to start out with the correct plugs.
eurolarva
Re: Spark Plugs 1990 Force 120
You need to post your model number. The 90A and 91C motor takes a UL18V and the 91D and 92C take the QL-76V plug for radio frequency interference and the L-76V if radio frequency interference is not an issue.
redlabel
The ID plate is worn smooth but the title says the year built is 1989, Model yr 1990, ID number 16185. Do you know of any other place to look for the specifics?
