Last fall when winterizing my two mercruiser engines (350 chevys) after running antifreeze thru the salt water circuit and fogging the engine with west marine spray can I pulled the plugs to spray some in each cylinder. On the starboard engine 2 of the plugs were extremely hard to unscrew, after finally memoving them I found that they had striped some of the threads from the head. My guess is that the yard mechanic from the previous owner had cross threaded the two plugs installing them.I went to the local auto supply store and bought a retapping die and after a lot of sweating managed to straighten the threads out and install the new plugs.I also have had this same thing happen on aluminum heads on both a vw and a mazda, and am positive I did not cross thread the plugs when installing them, and always put them in by hand in order to get them started before using a socket wrench.<br /><br />Is there anyway to avoid this problem? and does it matter whether you remove them with the engine hot or cold?<br /><br />Also I wonder if putting additional fogging oil in each cylinder is really required , after running it thru the carb.
