Re: Spark Plugs Fire Once in a While??
Sounds like a bad battery, dead cell or dry cells. Remove battery and get a load test done.
Could also be that your getting positive feed back through yr ground,but that could only happen if some of
your wires are in the wrong order. Excessive cranking or starting will also heat the battery
connections and could damage the starter. Over charging may be the cause as well. Take another
look at the rect. and make sure your wires are in the right order and check for bad grounds
throughout the entire area frm battery to motor. I,m sire that there are others that will chime in
with some good ideas as well.
