Spark Plugs for 1985 XP 150
Paladin51
Good Day Everyone:
What Part# spark plugs are recommended for my 1985 XP 150? I have used Champion & NGK in the past, both surface gap & regular.
What do the experts think?
Thanks
Paladin 51
HighTrim
Re: Spark Plugs for 1985 XP 150
Champions are what that motor was designed to use. I would shy away from the NGKs. Did you use the UL77V's or L16V's surface gaps?
Paladin51
UL77Vs. No real problem Just wondered if somebody had something better...
JDH
HighTrim
That is what I would stick with
Dhadley
A lot depends on what fuel you're using and what your top rpm is with an average load (set up). We'll assume that the motor is running correctly and according to factory stock spec. Right?
