Spark plugs for 1988 Force 125hp
rubennh
Hi,
I am going to replace the plugs, but i don't know which ones are the best or recommended for this engine. Should i replace the coils too? :confused:If i can get some advice it will be great.
Thanks!
jerryjerry05
Re: Spark plugs for 1988 Force 125hp
Are you having trouble or just normal maintainance?Replace with exactly what's in there.No if it's running you won't need to replace the coils.
Things you should check hoses,squeezie ball,water in the gas(a water/fuel seperating filter is good)loose connections(everywhere).J
rubennh
Thanks Jerry!, i will do that, is just normal maintenance.
