spark plugs wet with water
Chris1956
How do you know you are getting water on the spark plugs?
Tan is a good color for spark plugs. Water will usually bead up on spark plugs. In addition, water will usually clean spark plugs like new.
Chris1956
Gee, last I knew, water was clear, maybe rusty, but not tan. Sure it is not some gas/oil+combustion products?
buddylove48
i took the plugs out a swip the in side with a q- tip and it is black , i brough the motor with the tank and hose the tank was emplty ,but i`ll dump the gas buy a new hose and try again
