Spark Plugs
fostermutt
What spark plugs would you recommend for a 1981-200hp Envinrude. It has been misfiring when at idle speed. Is there a particular brand that performs better than others and should it be for marine engines only? Thank you for the suggestions.
JB
Re: Spark Plugs
JohnnyRudes like Champion plugs, FM.
rickdb1boat
Re: Spark Plugs
Champion UL77V or QL16V Surface Gap is recommended for your motor.
chippy
Re: Spark Plugs
If it is a 2 stroke motor. NGK plugs are the one's to use. ;)
rickdb1boat
Re: Spark Plugs
Not for OMC's. They don't like or run as well on NGK's....
cobra 3.0
Re: Spark Plugs
I have NGK platinums on my 1986 3.0 OMC and it runs beautifully. (I only bought the platinums because they didn't have the regular ones.) Mind you that's a GM inboard!
JB
Re: Spark Plugs
4 stroke inboard engines are a different animal than 2 stroke outboards, Cobra.<br /><br />"OMC" inboard engines are not, and were not, made by OMC.<br /><br />The question is about a 2 stroke outboard made by OMC.
