I have a 98' force 120. I just purchased the boat last summer. When I first got the boat I had all kinds of trouble starting the motor initially and once started it would fire right up the rest of the day. Then found that the spark plugs were getting gummed up. So now before going out on the water i will pull the plugs out and wipe them off and the boat runs fine for the most part and will start up in less than a minute. I'm just wondering what could be causing the plugs to get so gummed up every time? I have to mix the oil and the motor shows 50:1 for the ratio. I've been putting in the recommended amount of oil per gas. Could it be that the sparks plugs are not the correct ones or just need to be replaced?
thanks.
thanks.
