Spark Plugs
Tuna Van
I bought a 1995 Regal 202 SE with a Volvo 5.0 and I need to change the spark plugs. Do I need to know the exact model number for the engine or are the spark plugs and gap the same? The boat is currently stored pretty far away and I forgot to get the model number off of it before I left. I found the part number for a 1995 Volvo 5.0, but I am not sure it will fit all models.
Thanks,
Tuna
Gary H NC
Re: Spark Plugs
I'm pretty sure it will use the AC MR43T plugs.....
Someone should come along soon to be more specific...
Re: Spark Plugs
Ayuh,... As long as that's the Chevy 5.0l,... Those are the plugs you want....
QC
Re: Spark Plugs
Welcome aboard Tuna Van, I am going to move this over to the correct section although I believe you already have your answer. Helps others with searches etc. though . . . ;)
Don S
Re: Spark Plugs
Volvo didn't use a Chevy 5.0L engine in 95, they used a Ford. Now the trick is, is it EFI or carbed.
I would suggest you post your engines full model number before you get an answer, it also may not be a 95 engine.
Tuna Van
Re: Spark Plugs
It is definitely carbed but I will have to wait until I can get back up to it to post the full model number. I was hoping they all used the same plugs, but it looks like there could be different ones.
Don S
Re: Spark Plugs
On a Carbed FORD engine both the year before and the year after used the same plug. MotorCraft ASF32C
