Spark plugs
Durango318
Hey everybody, Iam not sure what spark plugs to get for a mercruiser 228, what gap would you recommend? Thanks
Re: Spark plugs
Ayuh,... Or bein' a Chevy based motor, AC Delco, MR43T spark plugs are standard fare,...
Durango318
Re: Spark plugs
Thanks for the replies, what do you think about getting some of those platinum plugs? Or should I stick with the standard plugs? Thanks
Volphin
Re: Spark plugs
Standard plugs will work just fine and last a long time. Plat is overkill.
I like your username BTW. What year is your D?
Re: Spark plugs
Ayuh,... A complete Waste of money,....
Durango318
Re: Spark plugs
I have a 98 durango slt 4 wheel drive, done a little work to it, jba headers, m1 throttle body, fast man intake, computer programmed, flow master muffler and y pipe, kinda wish I saved the money, it's horrible on gas.
Volphin
Re: Spark plugs
I hear ya on the fuel. Mine is a 01 SLT+ 4x4. Check out Dodge Durango Forum I used to be a mod and board member for the forum, and it is very informative. Not as active as I once was, but there is a lot of info on our Gen 1 Ds. Same username there. ;)
