spark plugs
bobstoy
2005 Volvo 4.3 the plugs i removed are AC DELCO 41-932. No auto stores seem to stock them or have a cross. They have red paint on them, so i have to guess they are original from 2005.
USA_boater
My 2004 same thing, even down to the red paint...just got it and had the same plugs...they still look good because those were 100k mile plugs for automobiles so on a boat I'd imagine they would last a long time...I am going to cross the AC-Delco number to NGK and use the NGK's...probably iridiums as I imagine there will be several options on the cross-over...I ran Iridiums in 2-stroke jet skis and they "seem" to run better than the OEM's which were cheaper copper plugs...not sure how they's do in a motor designed to run platinums...I guess I'll find out or do some more research first.
Ayuh,..... The plain ole AC MR43LTS will last 5 or 10 years,.....
Donno why you'd waste the money on exotic metals, that'll never pay it back,.....
USA_boater
Are the AC MR43LTS copper core? It would seem the OEM plugs for his 4.3 are factory platinums based on the part number he gave. In past research on this topic for vehicles, this was the summary of how I understood it:
- copper, produces better spark but lasts a shorter time before needing to be changed
- platium, not a "peppy" but lasts 3x longer than copper
- iridium, best of both worlds providing better spark than platinum but lasting longer than copper
Not being snooty, really wanting to learn because I too need to change the plugs and have never been a fan of platinum in anything I ever tried them in. But when I worked at a parts house a long time ago, I recall all the people who ran cheap copper plugs instead of the recommended OEM GM platinums who came back later because they burned up so fast...it made me wonder if there was something "different" about the ignition systems of vehicles that they chose to use platinums in? I doubt it on a boat but you never know; then again boats don't get as much use as cars so prob wouldn't matter as much.
alldodge
Just info; but I replaced the plugs for the first time (bought new) in my Rinker in about 2015 (about 20 years), and the original plugs where champion and looked fine with over 500 hours. Replaced with MR43T and have not noticed in changes in starting or running
Don892
I have a 2005 4.3 gl 2bbl carb 180 Horizon sxm out drive. Original spark plugs were 41-932 and had red paint on them. Bought my boat 5 years old. In 2009 I change these plugs to 41-993 as that what was crossed referenced. I took a color reading on one as best I could. High speed run idled into launch and checked one spark plug at home. Not the best test but plug looked ok. They been it the boat since 09 maybe 50 hours at most on my boat every year. Hope this helps.
Don892
jimmbo
My plugs are 14 yrs old(500 hours) and I have no intention of disturbing them
bobstoy
My plugs looked good,but being 13 years old and boat lacking power, i changed them. Didnt seem to make a difference
USA_boater
The AC-Delco 41-932 was a 100k mile plug in GM vehicles...a boat would take 1000's of hours to reach 100k miles I bet.
