Hi every one I need your help I am kind of tired, I check the spark on the spark plugs and I didn?t have a spark in the bottom cylinder (The one it was damp or Wet when i run the engine, so I take the flywheel off and check the condenser, points and coils everything ok ( points and condenser are new), I check the resistance on the primary circuit in the coil 1.2 Ohms , result ?ok? , I check the resistance on the secondary circuit coil to spark ?7.2 kOhm? , result ok , so I put back the flywheel , torque to 110 Lsb-Ft , start the motor without spark plus and test for spark, I saw a very good spark on both cylinders (I said Eureka), then I try again and I saw an intermittent spark in the top cylinder , The it happens the same in the bottom cylinder then I touched the spark plug cable and discharge me , (Do you thing I have a faulty cable?)
Can I make new cables out of an automobile cables the cables are 7.0 mm, Thanks for your advise
