Re: spark test
Ok Daviet, I am going to give you everything I tried. Working on it again today. As of now cyl 3 is the only one running this motor as I can pull off boots 1,2 and makes no difference. I checked compression again today cyl1 140, cyl 2 145, cyl 3 144. I went and got fresh gas. All 3 carbs full of gas in bowl. I sprayed fuel while running in cyl 1 and 2, no difference. all idle screws are set at 1 1/4 out. While running I did take the throttle linkage off cyl 3, the one thats running everything and advanced the throttle linkage and the motor revved, thats weird to me that something is running in these cyl, but when pull boots nothing. I put the plug from cyl3 into cyl1 just to check if it would then fire but no change. Prime bulb is strong when squeezed and when I changed gas, I left the drain screws out and primed and all three carbs getting good fuel. Spark gap was at least 7/16 on all 3 cyl, but was the highest on cyl3. Sorry for bouncing around here, cyl 1 and 2 plugs where wet with gas after pulling them, as cyl3 looked good. Fuel is spraying when throttle advanced. Rebuilt all carbs. well thats about it, whats next Admiral
