pcrussell50
- Sep 21, 2008
- 296
my 1959 super seahorse, 35hp, rds21b is running fine right now, but i always want a course of action already doped out in case i run into troubles. this thing has run well since the day i bought it, 9 months ago, and i almost feel as if I'm "cheating" or on "borrowed time" with it because it's 50 years old and i've hardly done anything in the way of maintenance besides install a thermostat, because the previous owner had removed it.
anyway, from reading posts around here, i've been sold on the idea of getting a spark tester, and why not, they're pretty cheap, too?
in shopping around, i've noticed two types:
1]inductive types that sense spark through the insulation, like a timing light
or
2]directly connected types, that you plug inline between the spark plug and the plug wire
as for the inductive type, i already have a timing light. what does the inductive spark tester tell me that my timing light wouldn't?
and finally the big question:
how do you "test" for adequate spark intensity? iow, how do you tell how "bright" and "hot" the spark is?
and if it turns out to be a weak spark, what do you change first?
guessing:
points and condenser first since they are cheap
then
coils, since they are more expensive
thanks
peter
or
guessing:
then
thanks
peter
